I have rebuilt them put in 140 jets and new intake boots and new plugs. I have checked for leaks with starter fluid no leaks. I purchased some guages from J. C. Witby. the best I can get them to sync is 10 on 1&2 and 5 on 3&4. When I start to sync 1&2 the rpms go to 4000. Is it possible one of the diaphram is leaking causing it not to sync.It is runing good with good throttle.So should I just not worry about it. Is there anywhere I can get a new minuki carb that will fit a xs.
