I had trouble with the loss of one or two cylinders after I washed the bike. It got worse to where it would happen in the rain. Now it happens even dry.
WOT I get maybe 60 mph, so I guess I might be running on two cylinders. It has been tough to troubleshoot because when I close the throttle and allow the engine to run at idle, it goes back to running on all four. I don't know what sparks aren't sparking.
....... FIRST try pulling off the plug caps, and inspecting the ends of the wires....look for corrosion, then cut off about 1/4" off the end of the wires, and then screw the caps back on! Inspect the screw on the inside of the caps where they attach to the wires for corrosion also, and clean as needed.
