Hey guys and girls, most of you know the dangers of mercury, but here is a caution just in case you dont know all the dangers.
This is from site: http://www.cdc.gov/niosh/hid6.html
Description of Hazard
[/QUOTE
COLOR=limegreen]In motorcycle and marine outboard engines with multiple carburetors, the vacuum pressure of each carburetor should be balanced. Mechanics commonly use mercury carburetor synchronizers for this procedure. Exposure to mercury may occur in two ways. Mercury carburetor synchronizers (gauges) contain about 40grams of mercury that can be spilled if these gauges are not handled or stored properly. Also, improper engine tuning can cause mercury to be sucked into the engine and released instantly in high concentrations from the exhaust system. Acute exposure to high concentrations of mercury vapor can affect lung function and possibly damage the lungs. Mercury can also enter the body through the skin. Prolonged exposure to mercury can damage the kidneys and the central nervous system.[/COLOR]
There are several other suggestions for example using gauges, or you may try the cheap carb synch tool thread.
or this one...
http://www.airheads.org/content/view/183/49/[
[/QUOTE
or this one...
