unused engine port
  • unused engine port
    I just bought a '79 XS1100 special with 20K miles on it. after bringing it home I noticed that there is oil dripping from a port on the front of the engine towards the top. This doesn't appear to be used for anything. Might it be a port for a oil cooler? Can Ii just loosen it, clean it up and reseat it to stop the leak?
    Thanks,
    Clark
    Any chance you're looking at the cam chain slack adjuster? See part number 8 in this microfiche view ?
    Ken Talbot
      that might be it
      Does that sit between the center two headers? If that is it should it be leaking? How do I resolve it?
        Yes, the cam chain tensioner is between the center two exhaust pipes, just below the cyclinder head gasket.
        No it should not be leaking. There is another ongoing thread (problem #2 by Pain) about this same problem. Also, do search (left column) and you'll see lots of other threads on this subject.
        There is a plug at the end of the tensioner which often pops out or leaks. It is a press fit. Seal with RTV or similar to stop the leak.
        Again, do a search.
        Rick
        '80 SG
        '88 FXR
        '66 Spitfire MK II
          I see the similarity now
          Since I didn't know what the component that was leaking was called I didn't know. Sorry. On the XS850 the tensioner is on the back side of the engine and doesn't look like the one on the XS1100 so I didn't connec the two in the other threads. I'll pull the plug, add sealent and put it back.
          Thanks again,
          Clark
