Hey guys.
I have the BP6ES plugs in my XJ1100 that the manual says are stock. It had BP7ES in it when I bought it. Is the 7 the more common plug to use? This is why I ask:
Although the bike rides ok, the carburation is a bit off. The settings for float level I read on here are nowhere near what I need to use to get it to run, so I set it up like the manual says with a clear tube. Now the float height measured with up-turned carb is about 2mm lower than you guys suggest, yet the plugs indicate a lean condition. I pulled the carbs, and set all the floats different, each 1mm up from the previous starting at 19mm from the carb body mating surface to the lower step on the base of the floats. This should have a) given me a super-rich reading and b)given me a different plug reading for each plug. I went out for a ride, warmed her up and did a 1/2-mile full-throttle run up a steep hill then chopped the engine. All four plugs are showing pure white, as in lean condition. I'm wondering if I am using too hot a plug for the test?
Any suggestions?
Any suggestions?
