MNS Exhaust - welding?
  • mixelpix
    • Sep 2004
    • 237
    • Utah
    on the I5 from LA to OAK the weld between the muffler and the exhaust header extension on the right side of the bike snapped clean apart!
    I made it home, the bike runs fine if not a little grumbly, but where the heck can i get that fixed?
    Can the muffler be welded w/the black ceramic finish?
    Any advice on someone to call in the NoCal area would be appreciated.
    Thanks!
    -pdk
    Your Mileage May Vary
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    Lookie here, what timeing!
    I had a hole in my muffler the PO had welded that needed redone. Not pretty but it's holding. The metal on these mufflers is very thin and hard to repair.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
      Hey Mixelpix,
      John in Texas just posted in the Member's Forum about a set of MNS pipes he found, they are asking a bit over $200.00 for them, he'll be happy to check them over more closely IF you can't get yours repaired to your liking, a possible alternative!?
      • Winterhawk
        • Jun 2004
        • 684
        • Missouri
        I've repaired lots of xs11 pipes using a MIG welder. Just make sure the chrome is ground off where the weld is.
        • dewibp
          • Jun 2005
          • 315
          • Work out of Dakota Dunes SD but live in eastern Iowa (Quad Cities)
          Winterhawk- Have you gone so far as to grind/polish your welds and rechrome an exhaust system?
          DEW
          One Red "Creation 1"
          One Black"Creation 2"
          One Black"Creation 3"
          One ???? "Creation 4"
          One ???? "Creation 5"
          One ???? "Parts Bike"
          All the above 1100 Specials
          78 Standard (Ruf Ruf)
          1980 Midnight Special
          1978 650 SE
          • Winterhawk
            • Jun 2004
            • 684
            • Missouri
            My welds need ground for sure...LOL But no nothing like that. I have shot some silver and chrome paint on them though..
            • Dark Horse
              • 121
              • Syracuse, Utah
              Make sure the coating/plating is removed from the weld area. Approximately 1/2" (12mm) from either side of the weld. Grind down the old weld to clean base metal. Re-weld the joint using the oxy-aceytlene process or Gas Metal Arc process (MIG). MIG can give the appearance of a good weld when in fact there is gross lack of fusion (called "cold lap"). It sounds like your original weld had this problem.
              Find a qualified (reputable) welder to weld it for you.
              Hope this helps.
              Bob Udy
              Assistant Professor Welding Technology
              Salt Lake Community College
              1980 XS11SG, The Dark Horse
              Bob Udy
              • mixelpix
                • Sep 2004
                • 237
                • Utah
                You guys are great!
                Thank you again, everyone! Y'all are the best, sincerely, Patrick Kennedy
                • noeleo
                  • Aug 2004
                  • 52
                  • Batesville, Arkansas
                  Winterhawk, You did remember it is MNS?
                  Midnight Rider
                  1980 XS1100LG
                  Intruder Alert!!!
                  2002 Suzuki Intruder VS800GL
                  XSive rules. Ride it like you stole it, unless it's mine. Then just PUTT, PUTT, PUTT!!!
                  Happy XSing
                    • 7641
                    Noelo;
                    The black on the pipes was called "black crome", and would weld as badly if not cleaned.
                    Patrick, I would have it welded, and then you could have the pipes powder coated. A gloss black should be close to stock.
                    Ray
                    • mixelpix
                      • Sep 2004
                      • 237
                      • Utah
                      thanks again - happy ending
                      Hi,
                      Just wanted to report that this last weekend I took a basic intensive MIG welding class and by the end of it I was able to successfully repair the broken pipe.
                      If you are in the NoCal area and want to learn about welding, check out The Crucible in Oakland:
                      Oakland-based industrial arts school with beginner to advanced classes in blacksmithing, welding, woodworking, jewelry, glass blowing, ceramics, and more.
                      Thanks again for all the suggestions.
                      -pdk
                      • 2fast
                        • Dec 2002
                        • 170
                        FWIW, I had my 4 into 1 crack completely off where it joins the megaphone. I brazed it together. This was several years ago and it is staying together just fine.
                        Miles to Go, Fuel to Burn
                        • 2bhappy
                          • Sep 2005
                          • 73
                          • Flint, Texas
                          Wiil powder coat hold up for exhaust pipes?
                          Marc
                          • mixelpix
                            • Sep 2004
                            • 237
                            • Utah
                            whaddya know
                            so I inspected the heat plate on the side of the bike that /didn't/ have the split and lo and behold - the right pipe is also cracking - not completely through, however, close enough!! this one is through the metal which joins the two into one - and not at a seam. ?!? I can fix it, but criminny! I wouldn't have even thought to look there otherwise. Personally, I am not too worried about the powder coat, I am just welding - the welds will be under the heat plate, but I suppose you could always grind frist, weld, then respray...
                            Just old parts? or maybe an indication that the suspension needs to be looked at?
                            Thanks,
                            -pdk
                            • John
                              • 5117
                              Chalk it up to old parts, vibration, and condensation. I had the same thing happen, in the same pace, to the MNS pipes that I had on my bike. There may be a low spot right there that holds condensation.
