rear brake caliper sticking xj1100
  • xj11john
    • Jun 2005
    • 440
    • Lafayette, TN
    Don't let anyone tell you it's not hard work
    Whew! I've been working on this thing for two days now, would be finished except I messed up and didnt plug the bango bolt up good enough when I used a grease gun on the right front caliper and guess what.... grease in the brake line!!!!
    I went over to a friend's hose that has an air compressor and we tried to no avail to blow the grease out, so then he came up with some steel braded wire just the right size, and that worked pretty good, I had brake cleaner coming out one end when I sprayed through it. Then the unthinkable happend, I saw some aluminum foil come out that end, (that is what I attempted to plug up the banjo bolt so the grease would not go up the brake line) well I quickly picked it out, I thought good there is some of what I was afraid was up there, anyway later I sprayed brake cleaner the other direction a few times just to make sure everything was clean, (of course after I left friend's house- with none of the good wire) You guessed it I plugged it up again!! of coarse it was close to 9 at night and I was'nt going back all that way and disturb him and his family, so I went to a local parts store that stays open till 9 and picked up so more brake cleaner and a roll of not as good wire, came home tried to no avail to get the wire down the line brake line for the front, and all rubber, so i called him and he is dropping of some of the wire tomorrow. So I tackle it one more day-which makes it a two whole day and however it takes tomorrow to wrap things up.
    But I did get the rear master cylinder clean and working, the plunger was very rusty, and so I took apart the plunger cleaned inside the bore with one of those green scrubby pads and some brake fluid as well as penetrating oil, clean as a whistle now, oh and cleaned it with brake cleaner and then put some brake fluid back in it to lubricate it. the back brakes are all ready to go. The front master cylinder plunger is not cooperating, it is not coming back to rest on the stricker of the handgrip like it is supposed to, tomorrow I'll put the line back on-if all goes well, and see if I can get it to work without taking the plunger out and cleaner the whole thing, if not well wish me luck, I'd hate to have to order a rebuild kit and have to wait for it for 3 days after this entire fiasco, burning my two days off, (I work nights so I'll use part of tomorrow-then sleep and back to work tomorrow night-hopefully on the beast!) thanks all for posting, we'll hollar at ya'll later, time for bed! bye.
    '82 Xj1100j
    "Ride for the Son"
    John
    • xj11john
      • Jun 2005
      • 440
      • Lafayette, TN
      Well, no luck on the front master
      the front master either has to be rebuilt or replaced, oh well I'm going over to friends and look at an xj 650 I think (I ended up getting a new front brake hose from it today) I'll go over there and check out the master, it looks just like mine, so we'll see if it's good, if so that some time saved-I'll just swap it out and then I should be good to go.
      Oh alittle off subject, and maybe I'll start another thread about fuel filters, I put 3 on- so two carbs had to share one, and the bike would not run unless I had the choke all the way on-of course I'm talking about those little clear plastic type filters, any feed back would be appreciated, and I'll start another thread on it if you would rather respond there.
      it will be called " xj1100 in line fuel filters-not getting enough gas."
      '82 Xj1100j
      "Ride for the Son"
      John
      • xj11john
        • Jun 2005
        • 440
        • Lafayette, TN
        update in front mc
        once I got the dust boot out the mc worked fine, so I just used another dust boot and it worked fine without rebuilding it.
        '82 Xj1100j
        "Ride for the Son"
        John
        • xj11john
          • Jun 2005
          • 440
          • Lafayette, TN
          update on rear mc
          well after cleaned out cylinder/plunger and reassbled, it started to leak brake fluid out of the cylinder/plunger, so I guess I will get a rear master cylinder kit for it, any good sourses besides Zanotti?
          '82 Xj1100j
          "Ride for the Son"
          John
          • xj11john
            • Jun 2005
            • 440
            • Lafayette, TN
            Well time to update..
            Well I added SS lines, but front master still leaking down-not fluid, just lever keeps coming in to handgrip untill no braking power.
            I think I may have caused this when I was messing with it when I replaced the line with a used rubber one last time, for some reason I had something inside the front outlet where the hose connects and I think I poked a hole in the rubber boot inside there??
            anyway it off to search for rebuild kit for the front master,
            T.C. - parts guru, do you have the best source?
            thank ya'll in advance, I'll post what I find.
            '82 Xj1100j
            "Ride for the Son"
            John
            • xj11john
              • Jun 2005
              • 440
              • Lafayette, TN
              update on front master ordered
              well I found this to be the best deal, so I guess I'll order from them.
              KL32-1084
              Front master cylinder Rebuild Kit - Yamaha RX50 XV535 XJ650 XV750 XV920 XJ1100 XS1100
              $21.58
              shipping = 6.00 - priority usps
              heres their linkwww.z1enterprises.com
              I'll let you all know how good it is/works.
              '82 Xj1100j
              "Ride for the Son"
              John
              • xj11john
                • Jun 2005
                • 440
                • Lafayette, TN
                better late than never!
                I guess it worked fine, because here we are in 4/2010 and still working fine, sorry about very late follow up!
                '82 Xj1100j
                "Ride for the Son"
                John
