I have cleaned my carbs and set the floats but noticed something strange. I have new K&L float needles and seats. (No I didn't use the jets.) On one of the needles the little spring loaded pin is only about half as tall as the other three. I had to bend the tang on the float alot to get the right float height. Will this affect anything? The bike seems to run lean on that carb and the bike pops and doesn't run well untill about 4k then kicks in pretty good.
Also when pulling the spark plug caps while running to help in my diagnosis, I get lit up like a Christmas tree. Just holding the cap while still on the plug I can feel a small tingle. When I actually pull it off spark jumps everywhere including up my arm. Is this normal or is it time for new caps?
