mpg decrease
  • DeanR
    • Jan 2005
    • 1499
    • Finger Lakes NY
    mpg decrease
    My gas mileage seems to have gone down by about 4 miles per gallon since removing the octopus. Has anyone else experienced this?
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
    Did you do any thing else to the bike that may have affected it? I can't see any reason why modifing the fuel delivery system should cause a change in milage.
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      My milage remains the same "post-octopus"
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • DeanR
        • Jan 2005
        • 1499
        • Finger Lakes NY
        No other changes. That's why it surprised me.
        80 SG
        81 SH in parts
        99 ST1100
        91 ST1100
        • pggg
          • 1609
          • NZ
          Lax, there's a simple explanation. The octopus was designed by the sensible shoes brigade to act as a power and speed reducer by limiting fuel flows. You're now actually travelling at twice the speed at the same throttle setting.
          • Dragonrider
            • 1219
            • Garland, Texas
            Are you turning off your petcocks when stopped? Are you SURE they turn off? You may be leaking gas at a needle valve in the carb while not running and that will reduce your mileage.
            It will also kill your engine if it's enough to leak into the cylinders and past them to the crankcase.
            Careful!
            CUAgain,
            Daniel Meyer
            • LoHo
              • Sep 2002
              • 1342
              • Fresno, CA
              Have you noticed any other changes in the bike's running? Some back-firing, or hesitation, or weaker throttle response? I know that evertime someone mentions a bike ailment on this list, my bike catches it...
              • DeanR
                • Jan 2005
                • 1499
                • Finger Lakes NY
                Pretty much the only time I've noticed any backfiring is on downhill grades which I'm told is normal and to be expected. No other problems.............Besides not starting a few mornings ago, when of course I needed to ride somewhere. Battery I think?
                80 SG
                81 SH in parts
                99 ST1100
                91 ST1100
