79sf front fork / caliper square braket - spare please?
  • 79sf front fork / caliper square braket - spare please?
    I was working on my 79sf front forks the other day and lost the square braket that fits on the underside of the fork where the brake caliper mounts. It's the bracket that holds the tops of the brake pads to the fork.
    Does anyone have a junk pair of 79sf forks with a spare?
    Ben
    1985 Yamaha VMX12n "Max X" - Stock
    Formerly:
    1982 XS650
    1980 XS1100g
    1979 XS1100sf
    1978 XS1100e donor
    Hey Ben. The SF doesn't have any square brackets that hold the pads to the fork. Are you sure it's not an F model fork assembly? Is it on a standard or a special?
      It's a 79sf. The axle hole on each fork is a few inches up the fork, not on the very bottom like my 80g.
      The calipers bolt on with a single bolt from the bottom side. Once they are getting tight, the pads swing up and there are tabs on the top of each brake pad that fit into the recessed slot on the fork mounting assembly. I lost the little metal bracket and I fear that was a time consuming mistake, since that part shows discontinued everywhere. My only hope now appears to be a junkyard or an entire set of forks....
      Ben
      Formerly:
      1982 XS650
      1980 XS1100g
      1979 XS1100sf
      1978 XS1100e donor
        Hi Ben i need some meself!!
        i saw them on www.partsnmore.com on a set of pads (might be rear tho) TOP CAT pointed me there or bike bandit
        Don't put all yer eggs into one basket ,,,case
          Looks like they don't come with the brake pads. Probably have to fabricate something...
          DRAT
          Formerly:
          1982 XS650
          1980 XS1100g
          1979 XS1100sf
          1978 XS1100e donor
            Hi Ben yep the front dont but rears do come with them?? not sure if they are the same?? never looked at my rears
            i do have an old caliper so will look might have to buy the rear pads just for clips
            prob get a manky set of forks for next to nothing tho
              Didn't even look to me like it came with the rear pads. I have a bracket on the other side. Worse case scenario is I have to fabricate one.
              Ben
              Formerly:
              1982 XS650
              1980 XS1100g
              1979 XS1100sf
              1978 XS1100e donor
                Maybe I'm lucky today. I think my Dad found it in the grass after I told him where I thought I may have lost it....
                Formerly:
                1982 XS650
                1980 XS1100g
                1979 XS1100sf
                1978 XS1100e donor
                  spoty on!!!!!!!!1
