oil filter bolt won't loosen...
  • UncleSpot
    • Jun 2004
    • 383
    • Home: Stockton, California Shop: Lodi, California
    'haven't changed my oil since March...
    the oil filter bolt loosened (then) with a ratchet and 12mm socket.
    When the new oil filter was installed it was 'snugged' but not 'torqued' real hard...
    'tried to loosen it tonight so I could change the oil AND filter but with the socket it would not budge - the socket actually 'slightly rounded' the bolt head. The socket would no longer work, so I tried a 12-point closed-end wrench - it just got worse...
    I remember a thread about an oil filter bolt that broke off in the engine block - deja vu is staring me in the face... I do not want to go there...
    ...any suggestions??
    __________________
    Ron Veil
    <Ron_Veil@yahoo.com>
    1980 XS1100SG
  • jacksf
    • 193
    • Daly City, CA
    This has happened to me many times in the past. The chances are that the bolt won't break off in the housing. I have used the Sears "bolt out set", item #952160. I think the #7 remover works, at least on my XJ. If it rounds off even more you can drop down to a #5. Might have to drive it on the bolt with a hammer, just don't use too much force.
    In the past when nothing would work I ended up using a dremel and cutting the head off the bolt, pulling the filter housing off and then using a small pipe wrench.
    It just takes time.
    Jack
    82 XJ100J Gone
    83 XJ750 Seca
      When you do get it off, take it to a welding shop and have them weld on a 19mm nut, right over the existing rounded-off 12mm. The bigger nut doesn't mean you will then have to tighten it up with gorilla torque, but you will be sure you will never have a problem in the future with it rounding off and getting stuck.
      • mitch
        • Oct 2002
        • 934
        12 point tools
        Throw them away and use a six point no more rounding of nuts...MITCH
        Doug Mitchell
        82 XJ1100 sold
        2007 Stratoliner 1900 sold
        • LoserShoes
          • Apr 2005
          • 524
          • Bangor Maine
          I'll second that! Get a six point socket, might have to tap it on with a small hammer. It REALLY makes a difference. Grips on the flats, not the corners.
          Steve
          73 Yamaha DT3 - DirtyHairy
          CZ 400 MX'er
          68 Ducati Scrambler
          RC Planes and Helis
          • fxrer
            • Aug 2004
            • 241
            • Bethlehem, PA 18017
            There's a filter cup and bolt for sale on E-Bay right now
            Rick
            '80 SG
            '88 FXR
            '66 Spitfire MK II
            • Snow
              • Oct 2002
              • 1041
              • Tallahassee, FL
              Just throw that whole horrid filter housing away and install a TopCat oil filter adapter like I did
                Re: 12 point tools
                I'll bet you can also get it to budge if you throw a strap wrench around the housing. It has about a quarter inch of play, one way or the other, before the allignment tabs stop it from turning. I would definately use a 6-point in conjunction with this however!
                • Geezer
                  • May 2003
                  • 2985
                  • Willamina, Oregon 97229
                  Re: oil filter bolt won't loosen...
                  Originally posted by UncleSpot
                  ' 'tried to loosen it tonight so I could change the oil AND filter but with the socket it would not budge - the socket actually 'slightly rounded' the bolt head. The socket would no longer work, so I tried a 12-point closed-end wrench - it just got worse...
                  Drill an indent just off center of the chewed up bolt head. Then stick a center punch in the indent and lean it into the direction you want to rotate it and tap away with a hammer. It takes a little finesse but it's not all that hard either.
                  Geezer
