My bike (78',E-model) has horriable ride quality from the front end. It feels like I have rigid forks. The front end hits hard on any bump.Since I have put it on the road(2-months) it has blown 2 head lights it hits so hard. I installed a T-kat fork brace, changed the fork oil to 10 weight, installed new fork seals and have also installed Progressive springs but this has not improved the ride quality at all. It is not bottoming out and if you lock the front brake and push on the front end the fork tubes move in and out so they are not locked up. I have the fork caps with adjustable preload and it does not matter wich setting I use it does not help! What could be wrong? Is there anything that can go wrong with the valving? It just feels like there is no suspension on the front at all as if the fork tubes were a solid piece of steel with no give!
