Jumpy tach
  • mastan
    • 349
    Jumpy tach
    Hey all:
    I recall seeing a post a while ago about a jumpy tach being a symptom of some kind of electrical problem. My 78e just started giving a jump whenever I shift gears. I did a search but came up empty. At idle, or at constant RPM, it gives a steady read. Any ideas?
    TIA,
    Mark Stanton
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    The tach is operated offa one of the leads from the charging coil.
    Had a tach that would sometimes play dead, hold steady or just jump around.
    I swapped in a spare voltage regulator/rectifier and cleaned all the fuse conections. Which one of these actions cured the problem, I don't know.
    • pggg
      • 1609
      • NZ
      Mas, the ancient plastic plug/pin connections between generator and tach can get dodgy. I've gradually ditched a lot of those plugs on my bike and replaced with single screw connecters. Not as conveniant to connect/disconnect as plugs, but at least you know your wiring connections are solid.
