I need to find out what the stock jet sizes are for a 1979 XS1100sf. I have just installed a K&N inbox air filter and the plugs are burning pure white. What size jet(s) should I move up to, and which jets will have to be replaced? Any help will be appreciated. Everything is stock on the bike except for the K&N filter.
Jet size and recommendations
Before you go into the jets, you might want to try resetting the float levels. I got an amazing effect on Tsunami by changing the float level by 2mm. It had been running way too rich - totally black plugs turned to a very nice light tan, all without changing the jets. You're going to end up taking off and replacing the carbs a half dozen times anyways before you're done - might as well start with this and see what it does for you.Ken TalbotComment
Hey Veeger,
I also use the K&N filter in the stock box but with a 4 into 1 Winning Preformance header. Stock jets are 137.5 mains and 42.5 pilots with the needle jet clip in position #3. After replaceing the the stock exhaust and air filter with the Preformance header and K&N filter I increased the main jets to 145's and left the pilots and clip location stock.
When I worked for Yamaha we would increase the main jet 1 or 2 sizes larger with intake modifications and 2 to 3 sizes with intake and exhaust modifications.Do'Lee
XS1100SF "Green Hornet"
(1) XS1100LG "Midnight Dream" Restoration has begun.
(2) XS1100LG "Midnight Madness" Waiting to be next
(5) multi partsters for bobber "Ruby Red II" On the list.
SR500H "Silver Streak"Comment
