coating intake boots
  • garyrc
    • 74
    • moline il/ quad cities/work in davenport IA
    does using rtv sealent on the intake boots really help? and if so how much do you put on and is there a trick. also will the clear rtv sealent work.
    Gary Chenoweth
    1979 xs 1100 standard w/mods "cujo" Nows needs a home
    Some mods include:
    stage 2
    4 to 1
    pods
    need paint help on tank though.
    other bikes are:
    03 shadow
    01 monster
    93 gsxf 650/mods
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    RTV works.
    Most cracks are cosmetic and the boots aren't leaking air.
    Test by spraying carb cleaner or WD40 on the boots with the bike running. Spray all around the boots on all the cracks. If the idle dosen't change then the boots are ok.
    To coat them and have them look nice use spray-on 'Plastic Coat' usually used to coat the handles of tools. Plastic dip is available too, just brush on.
    I bought new boots for my E and in 2 years they were as cracked as the 25 year old boots. None leaked.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • fxrer
      • Aug 2004
      • 241
      • Bethlehem, PA 18017
      You can do a search on intake boots, as there are several threads on this subject. Some members recommend something called Dip It (I think), a sort of paint on synthetic plastic. Claims it dresses up the boots nicely.
      But, as there is a metal "liner" inside the boots, you don't really need it except for cosmetics.
      Rick
      '80 SG
      '88 FXR
      '66 Spitfire MK II
      • garyrc
        • 74
        thanks pat.
        i did do the wd40 test at work during lunch and i noticed no change in idle. but my boots do looked badly cracked. when the bike is running i notice that the boots a pulsing almost as if the are alive and breathing is this normal?
        Gary Chenoweth
        Some mods include:
        stage 2
        4 to 1
        pods
        other bikes are:
        03 shadow
        01 monster
        93 gsxf 650/mods
          • 7831
          The pulsing is normal. almost all bikes do it, most people just don't see it. The black RTV (silicone gaskit material) will make them look almost new again.
          • garyrc
            • 74
            thanks,
            DiverRay
            Gary Chenoweth
            Some mods include:
            stage 2
            4 to 1
            pods
            other bikes are:
            03 shadow
            01 monster
            93 gsxf 650/mods
