Here's a vibebuster/cruise control in one. (for vibe busting only, hone out the twist grip.) Cranked big heavy bolts and nuts into the bar ends with a 5 foot pipe swinging off a wrench. The throttle stays on in any position but operates very smoothly. I find myself travelling on long trips with both hands resting on the tank. Who needs handlebars anyway?
Another position is leant forward, elbows on tank, hands under chin. You get plenty of gawking from cage drivers. Corners are tricky though. Sweepers are cool - you get to pinpoint the XS's balance well. Try it. Beware when blipping down at intersections with a static throttle where a small mistake might be fatal.
http://homepages.inspire.net.nz/~patrick/DSC00129.jpg
) to reach the bars comfortably, and so I got some heavy gauge boot straps and secured them to the handlebars just infront of the grips, and used them like horse reins, and was able to easily steer it that way, with my arms resting on my thighs, countersteering works well in that situation also!!! But I could easily sit up and grab the bars if I needed stronger control!
