speedo probs
  • chevy45412001
    • Mar 2003
    • 1412
    • Jacksonville Florida
    speedo probs
    my speedo cable recently broke. So i hgad a used one lying about,so i took out the cable lubed it well put it back in the sheath,installed on bike. Less then 120 miles and it broke again. Any place to look for problems? when working the speedommeter worked fine (no jumping or skipping) and the drive by the tire seemed fine and greased. Any thoughts or simmilar XSperieances? T.I.A
    1982 XJ 1100
  • garyrc
    • 74
    • moline il/ quad cities/work in davenport IA
    could be just one of those strange things. just an idea ..could it be the cable not the proper specs as in too thin, or perhaps to much torqe on the drive gear on the front wheel. just my thoughts but i am 100 percent sure someone else has a lot more knowledge about this than me.
    Gary Chenoweth
    1979 xs 1100 standard w/mods "cujo" Nows needs a home
    Some mods include:
    stage 2
    4 to 1
    pods
    need paint help on tank though.
    other bikes are:
    03 shadow
    01 monster
    93 gsxf 650/mods
    • Swampthing
      • Apr 2005
      • 6
      • Louisiana Swamp
      The internal parts of my speedo needed to be lube. I shot some pyroil silicone lube where the speedo cable goes in and lube up the internal gears for the trip odometer. It had a lot of drag on it before I lubed it. The speedo couldn't turn freely so something had to give. It was making sqealing noise right before it broke.
      Gone riding
      • pggg
        • 1609
        • NZ
        The only option might be to ride slowly. he - he
          Hey Chevy,
          Did it break in the same location as the OEM? Might have a kink in the casing that's rubbing against the inner cable, causing lots more heat/ friction, and eventually wearing the cable ?
          • chevy45412001
            • Mar 2003
            • 1412
            yea
            ya TC it broke in the same place right near the wheel end like right were the cable goes from round to square.I gonna get another brand spakin new one and see what happens.
            1982 XJ 1100
