Has anyone had a problem with their frames rusting through from the inside? Mainly the left tube under the motor. I found a spot that rusted through from the inside and found that the frame was rusted very thin. Almost scary thin. I repaired it and it will last probably a few years but that tube will need to be cut off and replaced.
This is not a rant and rage post. Just an FYI. If your bike sits outside alot, You may want to check your frame. Mabee with a sharp tip awl or some kind of poker. The repair started as a rusted through crack. When I opened it up to get to solid metal, It went to a dime size hole. While filling the hole with a plug and a welder, The repair went to aprox 6 inches long and the width of the tube.
He's TrukLeon, PM him, or he may see this and contact you directly!? Hope he doesn't mind me offering it for him!
or am I way off base here
.. Anything is better than half which is what the frames are reduced to even though the integrity is more than likely less than that.. The old saying comes to mind your chain is as strong as your weakest link
