Hey all, and AUXTIAN,
He had some worn motor mounts, and found out that 2 of the three are no longer available from Yamaha, only the lower rear one, has a flat edge to it is still obtainable!
So...he needed the dimensions for the possibility of finding suitable replacements or custom fabricated. I had just received a set I won in a lot on Ebay(needed the chrome swing arm covers in the lot!
), and so I went to measuring....photodocumenting and diagraming! Here's the pix and info. I forgot to put on the diagrams before I uploaded them that ALL measurements are in mm.
The Yamaha # for the one you can still get is:
2H7-15326-01-00 Lower Rear, flat edged available ~$20.00
These are the ones you can't get:
2H7-15316-01-00 DC Lower Front
2H7-15336-00-00 DC Upper Front
The lower rear use a 12mm diameter bolt thru it, the lower front and upper front use 10mm bolts. I stated the size of the I.D.s on these are 0.1 larger to allow room for the sized bolts!
Hope this helps him and others needing to replace their motor mount bushings!
