I have a developing concern with my front brakes. I seem to have lost pressure somehow. I have checked for signs of leakage and can't find any. All lines are dry, and there is no seepeing or drips from the front m.c. I just measured for lever play (which was the first thing I noticed, I had way too much) and holding the tape at a right angle to the grip, I centered an inch mark on the ball at the end of the lever and pulled. About 5/8" of free play before it hits the plunger on the m.c. When riding, I can pull the lever all the way in as far as she'll go and the nose dives nicely. Problem is, at full pull, one of two things should be happenning: 1) The bike should be standing on her nose, and/or 2) I should be flying over the bars.
Could the plunger the lever pushes be sticking pressed in like it is? Wanted to get some feedback on the problem before I went out and started spraying with WD-40 to see if I can get the plunger unstuck so it will come all the way out. As usual, any and all suggestions are and will be greatly appreciated. Thanks in advance brethren.
