Here's what I've done.....
Sent carbs away to motorcyclecarbs.com for professional cleaning/diagnosis/repair
intstalled carbs, runs real rough from "idle" to 4000 rpm
rpms will sometimes hang at 2500 or 3000 then slowly drift down to 1200 idling really rough. won't idle at 1000, will stall
sprayed wd40 in to carb boots while idling high to check for leaks, no sign of leaks.
checked valve clearances. all in spec.
checked all fuel/vacuum plumbing, looks good
only thing i havent done which i will when guages come in is carb sync, but i dont think that will solve the problem since they were bench synced pretty close.
any help?..thanks..Phil
