Runs great, dies intermittently.
    I have a bike that, once warmed-up, would idle slower and slower until it would die. When I lowered the floats a tad bit, it held a low idle just fine.
    Originally posted by KJK
    When it would die intermitently I did have all lights, and gauges. Elecrtricly and visualy nothing changed during the 1-2 second stopping of the engine.
    • KJK
      • 20
      • Corpus Christi
      This fix has been a long time coming! Thanks to all of you because I have referred to the about information several times when I had a little time. I finally made enough time to shoot the wiring, and stumbled across a bad fuse holder. While I was moving it I heard a rely make and the break. From this, I discovered two of three bad fuse holders. I have replaced the three 10A fuse holder (glass) with a water tight two blade type fuse. She runs now just as before. Again Thanks.
      Kevin
      1981 XS1100
      Eleven Special
