Homemade YICS
  • GNEPIG
    • Apr 2005
    • 1656
    • fl
    Homemade YICS
    Hi, I have recently removed the head from a late model 1100 engine that said YICS on the top and had always wondered what exactly a YICS could be until I did this. I thought 'WOW' all it is is a balance tube between carburator intakes.
    Then curiosity got the best of me & I wondered what good this would do to the running condition of my motorcycle. I had seen the balance tube before on my '73 Norton Commando (sweet bike but that's another story and site) but I didn't have a clue then either because it went away when I changed the carburators to the Mikuni brand.
    So I hooked a piece of hose between each of the intake manifolds vacuum ports. My first impression was a great one - it cut vibration in half all over the rev range, the little flat spot between idle and go -- gone. The familiar noticeable vibration between 3-4,000 rpm -- gone; power seems to be very smooth and seamless after I did this. Life was good!
    But THEN (you knew it was coming, didn't you?), I went for a top end blast to see what this new modification was like wide open and noticed how really lean the bike was up top. Couldn't get the bike to go over 95 mph and when I rolled back, it went a little faster for a second i.e. lean condition.
    So my question is, (after this long a** explaination) has anyone else tried to make their own homemade YICS? If so, how was your experience and what modifications and jetting did you have to perform?
    The bike that I performed this on is the '79 XS11 Special with stock exhaust, stock air box with K&N air filter and snorkle cut down to 1 1/2". 140 Main jets & the float levels are at 25.7 mm as per the book specs. Everything else is stock.
    Gene
  • pggg
    • 1609
    • NZ
    Het GNEPIG, not a yics but apparently if you drill a hole through all 4 cylinders, the vaccuum dissappears and the pistons have no drag. The combustion powers the intake . An instant 15 horses. Dont ask me how to drill the holes.
    • Bill
      • 368
      • Fairfield, Calif
      Re: Homemade YICS
      There are LOTS of great tech tips here at XS11.COM, including these:
      Norm Kokes' Homemade YICS Tool
      and
      Jetting Recommendations
      Bill K.
      1985 Yamaha XJ700 Maxim
      1986 Yamaha FZX700 Fazer
      • GNEPIG
        • Apr 2005
        • 1656
        • fl
        .. thanx bill, norm's storie about the yics tool did prompt me to try making my own yics ..i was wondering if anyone had tried this yet
        i am interested in how it worked for them
        and i like shairing my experiance with this, if any one is interested
        it seems to be a pretty good one
        .. also i would like to know how that drilling the cyclinders modification goes for that guy ppg sounds interesting,
        im pretty shure of the out come of that one but when you try it let us know
        and if you dont mind the big shipping cost from us to nz, i have another set of cyclinders i can sell you
          A few years back, a number of guys tried plumbing the vacuum ports together to simulate the effect of the YICS channel on XJs. I just don't recall ever hearing back that it made much difference over having a fully, properly tuned engine.
          YMMV...
          • pggg
            • 1609
            • NZ
            GN, ah... the 15 extra horses could be stretching the truth just a tiny wee bit! GSXR1000's have their cylinders connected by small holes in the cylinder walls. Supposedly gives a boost.
            • GNEPIG
              • Apr 2005
              • 1656
              • fl
              .. i cant recall the article i read it in but yamaha drilled a connecting hole between the cylinders at the base for a better crank pressure flow... i think it was on the FJ ..and it did make a substantial difference ...those were great bikes also
