xs Handle bars
  • scdxs
    • 8
    • NJ
    xs Handle bars
    HELP ME WITH THIS GUYS
    I just picked up my "new" 1980 XS last night and on the ride home noticed a considerable wobble in the handle bars. Has any one experienced this? I noticed bushings at the triplr trees is this the answer? If so.not can it be reduced/eliminated? Thanks.
  • LoserShoes
    • Apr 2005
    • 524
    • Bangor Maine
    Do they look like the original bars? Could be someone put in a set that was too small a diameter.
    Steve
    80 XS1100G Standard - YammerHammer
    73 Yamaha DT3 - DirtyHairy
    62 Norton Atlas - AgileFragile (Dunstalled) waiting reassembly
    Norton Electra - future restore
    CZ 400 MX'er
    68 Ducati Scrambler
    RC Planes and Helis
    • scdxs
      • 8
      • NJ
      Stock Bars
      They are stock bars. The wobble goes through the tripple trees to the nuts below. I was thinking the wobble comes from the bushings. I assume you don't have this on your bike? Any remedy? Do I need a new triple tree?
      • John
        • 5117
        You say there are bushings, and nuts attached to the handlebar risers? They are not cast directly into the upper triple tree? The OEM upper triple clamp for an XS11 does not have detachable risers mounted in rubber, they are cast into the upper clamp. If you have rubber mounted risers on an XS11, then they are not original. The XS750-850 does have the rubber mounted, detachable risers, and it's sounds like someone has swapped out the triple clamps.
        You talking about an XS11, aren't you?
        • scdxs
          • 8
          • NJ
          xs11
          Yup xs11! Sounds like a swap. To you're knowledge, are the 750 and 850 supposed to wobble (perhaps to reduce vibration)?
          • John
            • 5117
            Just the very nature of the rubber bushings should allow for some flex, but I wouldn't think that a wobble would be built in. I used to own a 79 XS750 Special, but that was 15 years ago , and I don't remember just how much give there was in the bars/bushings. I would recommend getting the proper triple clamps though.
            • LoserShoes
              • Apr 2005
              • 524
              • Bangor Maine
              What your top triple tree should look like.
              There small differences between Standard and Special, but this should help.
              Steve
              CZ 400 MX'er
              68 Ducati Scrambler
              RC Planes and Helis
              • MartyA
                • 2148
                • NW PA
                If the wobble just showed up suddenly, and when you are riding in a straight line, you might have a bubble in your tire, or a broken belt. Mine suddenly started wobbling over 60 last fall, found a missing wheel weight.
                Check air pressure - front and rear tires.
                If the wobble is on the sweepers or curves you should look at everything that tightens. Steering head, axle, handle bar bolts...
                How old are the shocks? Worn out shocks can cause wandering.
                Marty in NW PA
                This IS my happy face.
                • beechfront
                  • 673
                  • midwest
                  this probably does not apply to you - but on my bike, if i let go of the handle bars it will begin to shake violently. and this only happens when i have my luggage rack installed. very strange.
                  • excess11
                    • Oct 2004
                    • 256
                    • Rockville Md.
                    Reply
                    If your bikes front end shakes when you let go of the bars it sounds like you should check your wheel bearings and also the bushings in the rear swing arm. Are your tires worn uneven,more wear on left or right side of tire. That would indicate one of these problems
                    Dan ( A.K.A.- MacGyver )
