front brake problem
  • DeanR
    • Jan 2005
    • 1499
    • Finger Lakes NY
    front brake problem
    My front brakes 'pulse' at Very Slow speed when stopping. It's kind of a bucking sensation. Very annoying. Would that be called pulsation? Don't think it was there the first couple times out this year. Did notice it last year but not, I think, all the time.
    In looking thru past threads, there are no leaks, rotors are clean and not warped and the brake lever does not pulsate. Master cylinder kit put in last year just before I got the bike. Any thoughts? I would like smoooooth stops!
    Thanks everyone.
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
  • Snow
    • Oct 2002
    • 1041
    • Tallahassee, FL
    It sounds like warped rotor(s) to me. Someone way back told me to check rotors with a pane of glass - just lay the glass flat on the rotor to get a good idea wether it is warped or not.
    • pathfinder
      XStremely XSive(Deceased)
      • Apr 2004
      • 483
      • Houston, TX
      Sounds warped to me too.
      78XS11E
      • CMA1
        • Jul 2003
        • 114
        • Ontario, Canada
        Special.... could it be a misalignment of the calipers on the fork mounts? They gotta' be lined-up straight, or they will 'hump' when hot.
        Loosen the axle nut, check clearance on both sides, between the inner pad and rotor (on both sides) align then retorque axle nut.
        '79 Special
        • DeanR
          • Jan 2005
          • 1499
          • Finger Lakes NY
          I only notice it when stopping. Don't know if speed just masks the affect or not. And it happens right from starting out with cold brakes to the end of a ride. Rotor runout checked out ok.
          I don't know if it's any clue or not, but when I use the air compressor more brake dust blows out of one side than the other.
          80 SG
          81 SH in parts
          99 ST1100
          91 ST1100
          • randy
            • Dec 2003
            • 4521
            Are the rotors contaminated with something like oil or are there rust or dirt spots?
            My 81 SH did that and it was warped rotors, so bad that the lever pulsated, but only on hard fast stops.
            • DeanR
              • Jan 2005
              • 1499
              • Finger Lakes NY
              Still kind of stumped by my 'bucking' front brakes. I recently hit the rotors lightly with emory cloth and brakleen. It seemed to eliminate the pulsating for the next ride or two but becomes noticeable again quickly. I keep the rotors clean and blow out the whole area with air from time to time. The fact that it briefly goes away and that they measured out ok would seem to eliminate warpage possibility. Anybody have any other ideas?
              Thanks.
              80 SG
              81 SH in parts
              99 ST1100
              91 ST1100
              • LoserShoes
                • Apr 2005
                • 524
                • Bangor Maine
                You might check and see if the pads are contaminated with oil or something. Surface them lightly on a piece of sandpaper on a sheet of glass to knock off the top layer. Good Luck.
                Steve
                73 Yamaha DT3 - DirtyHairy
                CZ 400 MX'er
                68 Ducati Scrambler
                RC Planes and Helis
