Hi All
If any of you have trouble with your carbs and can't find anything wrong and all the float heights are correct, check this:
After many months of trying to fix one of our members carbs, I eventually figured it out. They had been having intermittent flooding problems and it wasn't always the same carb that was flooding. All the float height settings were correct and nothing would be found on dismantling.
What I finally discovered was that the tang on the float arm (arrowed in 1st picture) was allowing the needle valve to drop too far and jam (you can actually see the valve in the jammed position above the arrow). This is what caused the carb to flood but the process of removing the carbs always unjammed the valve.
The normal setting can be seen in the 2nd picture.
I hope this is of use to someone out and may prevent a lot of pulling out of hair.
Keep revving.
Keep revving.
