I had some starting problems because of an oversized choke hole previously but have since solved that problem by installing new floatbowls tonight. Also intalled the EMGO pod filters.
I had also had issues with exhaust smoking. Now that I have this set up is it possible that exhaust smoking is due to my idle mixture settings. I did play with them a bit before removing the carbs the last time.
Smokes from both sides and the plugs look dark (but dry). 2 plugs are black except for the electrode and "gap wire" which are dark gray. The others are pretty well black.
Is this most likely related to fuel mixture?
My oil level is staying the same so I don't THINK it's oil....
Tom B.
Tom B.
