A fused DC terminal for electrical accessories up to 50w???
  • OpFlash
    • Feb 2005
    • 197
    • Chicago
    Hey there was reading an old article on the xj1100 and came across this as a feature for the bike anyone know of this and where its at is this just the fusebox? whats up
  • chevy45412001
    • Mar 2003
    • 1412
    • Jacksonville Florida
    on the XJ
    would'nt that be the aux. under my side panel near the fuses?
    1982 XJ 1100
      Hey Opflash and Chevy,
      That's right, it's just the acc. terminal on the fuse box under the right side cover. When I did my blade fuse conversion, I included that in the circuit, have my horns and aux. driving lights running thru it!
      • Hobbit
        • Nov 2002
        • 372
        • Jacksonville, FL
        50w
        50 watts is still only about 4 amps, not a whole lot when it comes to extra lights.
        I know that T.C. used some LEDs to reduce the total current draw.
        Walt
        80 XS11s - "Landshark"
        79 XS11s
        03 Valkyrie
        80 XS Midnight Special - Freebee 1
        78 Honda CB125C - Freebee 2
        81 Suzuki 850L - Freebee 3
          I just reviewed my owner's manual, and the wiring schematics, and aside from the 50 watt rating for the aux. terminals, I can't find a diagram for the aux. circuit, so don't know what wire it's tapped from? However, the fuse rating says 10 amps, which would be around 120 watts maximum for that fuse!? I ran that circuitl thru a 15 amp fuse, the gauge of the wire seemed similar to the other main circuits!
          But yes, I did an LED conversion for my brakes, turn signals, which freed up some spare wattage/amperage to be able to better handle my 50watt each halogen driving lights!
            If I'm not mistaken, Clymers says that the aux fuse is 20 amps. I have my two Fiamm horns on that circuit.
              Hey John,
              Sorry but you are mistaken, Clymer's and the OEM manual both state 10A Slo-Blo fuse for Aux Plug!
                Oops
                That's what I get for quoting the book this many years after reading it.
                Ya know, I forget what they say the first thing to go is....
                • scott0757
                  • Jun 2007
                  • 130
                  • Syracuse, NY
                  TopCat - I am curious about your fuse box blade conversion. I just broke off a fuse holder for the headlamps while trying to diagnose a short in that circuit. Apparently it got pretty hot and the one side snapped when I tried to might it grab the fuse tighter. Real bummer.
                  How did you do this conversion? Is there a place you bought the kit from? I'm SOL for now unless I temporarily rig a fuse holder on this circuit so I can trouble shoot it. It appear the fairing may be the cause as when I disconnect it, there is no short and I get my speedo/tach lights back and the fuse stays cool... I hate chasing shorts..
                  Past Rides:
                  1969 OSSA 250 Pioneer
                  1979 XS650 Special
                  1978 Honda CB750K
                  Current: 1980 XS1100SG
                    How about skirts?
                    • scott0757
                      • Jun 2007
                      • 130
                      • Syracuse, NY
                      More interesting, but my wife wouild prefer I stick to the shorts (that sounded bad too!) :-)
                      Past Rides:
                      1979 XS650 Special
                      1978 Honda CB750K
                        It has been hot...
                          Fuseblock Conversion!
                          Hey Scott,
                          No kit really, but a more modern fuseblock that you can mount!
                          See this first tech tip and
                          then this second tech tip for photos and instructions and where to get one!
                          • scott0757
                            • Jun 2007
                            • 130
                            • Syracuse, NY
                            Del City sells the block for under $5 and when you got to the check out, they have a $25 min order limit! Even adding fuses and terminals and a second 4 circuit block, I'm only up the about $14. Hate buying what I don't need...and then paying to ship it too.
                            Do you have any left for sale? Guess I'll just do it...
                            Past Rides:
                            1979 XS650 Special
                            1978 Honda CB750K
                              Shhhhhh, Scott,
                              Your telling my secrets!! That's why I buy a block of 7 fuses blocks and resell them to the members at just a modest price to cover the extra expenses of shipping, remailing, Paypal! A recent member though wanted to buy 5 of them, so I told him about Del City, and he got 8 for the price he would have paid me for 5! IF you followed the links above, you would have read about HOW to order one from me! I also sent you an email stating the same. I can understand your desire to get things as quickly as you can, but haste makes waste.....
                              Sometimes you need to wait for responses here before jumping into action!
