diaphragms
  • bryzx2
    • Jun 2004
    • 28
    • Wisconsin
    diaphragms
    I am already out $250 for nothing really and would be towing back home to look at if the work isn't done. They want $100 each for the diaphragms.
    Well, cut your losses and get that thing home. Even if you should mess something up, it won't cost you what a dealer would charge you. Hell, you could ship them to somebody here and get the work done right and a whole lot cheaper.
    • Geezer
      • May 2003
      • 2985
      • Willamina, Oregon 97229
      Re: diaphragms
      Carb diaphragms can be easily repaired wirh Yamahabond 5. A tube of YB5 will run you around 7 bucks and you'll have plenty left over...
      Geezer
      • andreashweiss
        • 951
        carb diaphams
        I have two carbs (bank set of two off of some Yamaha probably a 650) mikuni that I do not need. I can tear them apart and send you the diaphams provide me a shipping address. Please get someone on list to confirm that same size mikuni carbs all use the same diaphams. if so these two are yours. I only have two.
        • Hepcat
          • Apr 2004
          • 190
          • Captain Cook, HI
          I'm gonna have to double check this one, but I'm pretty sure when I took the diaphragms out of my XS they were the exact same size as the ones out of my brother's `72 Honda CB350 twin. I'm not sure that the cb350's diaphragms are any cheaper, but it's a start. I'll have to swap them out and see if they actually work. As I recall, we took measurements but never actually swapped them.
          HTH
          __________________________
          Jon Groelz
          '82 XJ1100J-John
          '78 XS1100E-Name Forthcoming (It's a Girl!)
          • ScottS
            • Apr 2005
            • 27
            • Vincennes, IN
            Re: carb diaphams
            If they do fit the Actual size will be a 28MM slide.
            • xExcessive 1120
              • 37
              • 260 Overview Jeffersonville,VT. 05464 USA
              A Resevoir Of Diaphragms
              I May Have Missed the Three Day Rush On Resevoirs, But Have Twelve Sets Of 78 + 79 Carbs
              Christopher. "The Gimp"
                FYI,
                The later model 650 and XS11 show the exact same part # for the vacuum slide for the 81 year. See Below:
                3H5-14940-00-00
                The earlier years show differing 3 letter prefixes, but the root part # is the same as above, not sure if the different prefix could indicate a different sized needle???
