Oil cooler thermostat options
  • 81xsproject
    • 3185
    • Fortuna, CA
    I did some searching for oil cooler thermostats after reading about the lockhart one in the product evaluations and I may have found a lower priced ($43) alternative here http://www.batinc.net/thermos.htm. I found a lot of options, but I don't know what the optimal running temp range is and most required the screw in oil hose.
    I think I might give this a try.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
  • 81xsproject
    • 3185
    • Fortuna, CA
    Is no one interested in this? I will eventually get one , but I was wondering, what is the desired opperating temp?
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
      • 7844
      The oil should bypass the cooler until it reaches about 200 F. The high end of the oil temp is about 275 F. I used to see 315 on my '78 dresser running at 125 up I-5 in the summer. You really want to try and keep the oil temp below 300, and 325 is death.
      • 81xsproject
        • 3185
        • Fortuna, CA
        That sounds really high to me (even though I obviously don't know any better). All the thermostats I have been seeing are set for 180 including the Lockhart which is 160-180.
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
