question about vetter bags
  • xswilly
    • Jul 2003
    • 462
    • Hollis, maine
    i have a 79 xs standard with the detachable vetterbags
    i aquired the bike without the keys
    my question is do the keys that unlock the covers to the bags
    also detach the bags, or are the keys different
    i had a locksmith make a key to the bags
    easy as the cover had fallen off, but the key doesn't fit the lock
    to detach, they are rusted some, so should i keep on turning it or bring the frames to the locksmith too
    of course that would involve taking the framework off of the bike
    much harder when the bike doesn't run
    http://home.securespeed.us/~xswilly/
    78E main ride, since birth the "good"
    78E Parts, the "bad" fixing up now
    78E Parts the "ugly" maybe next year
    79F Parts
    80G Parts
    75 DT 400B enduro
  • Jerry
    XS & TRUE XJ GURU
    • 3023
    • Elma, IA.
    I have one original door lock, and that key fits both locks to remove the bags. The other door lock was missing, so I replaced it with a generic lock from Tru-Value hardware. Interestingly enough, that key also fits the lockable pocket in the fairing......
    Assuming the locks in the doors have not been changed over they years, the same key should work all the locks.
    Jerry Fields
    '82 XJ 'Sojourn'
    '06 Concours
    My Galleries Page.
    My Blog Page.
      Yes, Mine is like Jerry's. Same key for all locks. I have a suggestion. I have found that the bags can become detached when hitting a big bump in the road. The bullet shaped thing can force the retaining clip apart and cause it to release. I have played with the mechanism, but I still do not fully trust it. I used a nylon strap through the handles just for security. YMMV
      • Jerry
        XS & TRUE XJ GURU
        • 3023
        • Elma, IA.
        About bags falling off.....
        One of mine did this just after I mountd the set. Close examination revealed the problem. Vetter used a stiff wire, bent in a long "U" shape, to hold the tapered point of the bag mount in place. ( I really need to take pictures of this...). Each leg of the "U" fits into a grove on the bag mount. One of my wires was broken. The cover that held the "U" in place was rivited on. I ground out the rivits, removed the broken wire, replaced it with wire from a heavy-duty wire hanger (same size as original wire) and put the cover back on using small bolts with Nylock nuts. Literally thousands of miles later the bags have never come off, and I do a fair amount of riding on rough roads.
        I've also replaced the hinge rivits, which were loose from use and age, with small bolts and nylock nuts. A Dremel tool works great for grinding the old rivits out.
        The moral of this story is.....maintenance on your Vetter luggage may be necessary from time to time.
        Jerry Fields
        '82 XJ 'Sojourn'
        '06 Concours
        My Galleries Page.
        My Blog Page.
