Recommendations on Carb Slide Diaphragms?
  • Brian_D
    • 355
    • Gardner, KS
    Has anyone had troubles with the carb slide diaphragms available from partsnmore? or is there any reason I should be spending the additional $$ for original Mikuni diaphragms from cycle-re-cycle?
    Obviously, I've just begun rebuilding the carbs and will be ordering parts from both companies including Mikuni Main Jets and a carb rebuild kit (containing only the float bowl gasket, and float valve assembly).
    thx.
  • tab1324
    • 303
    • Brooklyn Park, MN
    are they bad?
    The diaphragms can be repaired in most cases. Go to your local Auto store (Napa) and ask them for a product called "Plasti-dip". It can be brushed onto the diaphragms repairing any small holes. To inspect them, put a small flashlight up against one side of the diaphragm and look at the other side. If you see light, repair the hole.
    the stuff is great - works well on carb boots too.
    Tom B.
    • Brian_D
      • 355
      • Gardner, KS
      I've picked up a couple spray cans of Plasti-Dip already and have been contemplating this as a temporary fix, however, more than one of the rubbers have a weak spot that looks like somebody ran a small zipper across the diaphragm.
      BTW, what should be used to clean the diaphragms and carb boots prior to treatment with Plasti-Dip?
        I would use nothing stronger than dish washing liquid, and a cloth or sponge.
