XJ side cover tip
  • lsippell
    • Sep 2003
    • 216
    • Mayflower, Arkansas
    XJ side cover tip
    I was reassembling my XJ's side covers this evening after having just painted the plastic inserts. Last fall, when I tore the bike apart, one of the things I ordered was new grommets but not the spring nut/retainers for the plastic insert. Since I use to own a body shop I thought I should have dozens around, not! Well, desperation is the mother of invention. I found out that taking an s/s 6mm lock washer and mashing it using pliers so the split end slightly overlaps works better than the original. I seated them using a deep socket that would just fit over the stud and tapping it with a small hammer.
    Not only does it hold good, it will be much easier to take off the next time.
    Louis
    "There is no mechanical problem so difficult that it cannot be overcome by
    brute strength and ignorance" And possibly some Mouse Milk!
    '82 XJ1100J
    LED Dir and running lights
    LED Tail/Brake lights (4) one flashing
    Modulated H/L
    PIAA Driving lights
    YICS Eliminated
    750 FD
    Yamaha Factory X-1 Fairing and Luggage
  • OpFlash
    • Feb 2005
    • 197
    • Chicago
    sweet tip
    • lsippell
      • Sep 2003
      • 216
      Yeah, I always hated them little pesky spring nuts ever since I broke a stud removing one on the XJ I had in 1982 with it only three mo. old. After that I always have cut them (the spring nut) off and replaced them with new ones, untill now!
      Louis
      '82 XJ1100J
      Modulated H/L
      PIAA Driving lights
      YICS Eliminated
      750 FD
      • chevy45412001
        • Mar 2003
        • 1412
        • Jacksonville Florida
        ace is the place
        i just went to the local ace hardwere and got the replacements only cost like a nickle.
        1982 XJ 1100
