Steering head bearings
  • brcree
    • Mar 2010
    • 388
    • S.C.
    bearing
    Nate: So far the bottom bearing still looks good. If I can get the bottom race out of the titless frame and back into the good frame I may be ok......the bearings are of the tapered kind.
    At this time:
    1985 Goldwing Innr.
    1976 cb 750 cafe racer
    2007 vtx 1300
    81 sx 1100 s h
    81 sx 400 special
      Don't worry about matching these bearings and races; 99% of all problems with these are neglect/maltreatment/rust, not wear. If both parts look good after cleaning and move freely, repack 'em and go...
      Same thing goes for the swingarm bearings.
      • xssiveone
        • 766
        • Windsor,Ontario,Canada
        Originally posted by brcree
        Have question: I'm in the middle of repainting my frame and needed to replace the steering head bearings. I've gotten the races out but......how did you guys get the bottom bearing off the shaft?
        As Nathan suggested, I used a Dremel cut off wheel. After you split the cage and remove it and the rollers, cut the race almost all the way thru and then place a chisel in the slot and give it a good whack. The race should split at that point.
        Brian
        remembering the same thing!
          Gawd Brian,
          that's a load of effort! Put a cold chisel between the race and the tree and give it a mighty whack. Do the same the other side. Keep alternating. The race will work off like a stuck sliding window. The diameter that the race fits on is only mebbe a 1/4" long so it'll soon be free.
          • CaptonZap
            • Jun 2010
            • 1748
            • Denver
            And now is the time to buy some more tools.
            And if you can swing it, that means you need a press. If SWMBO nixes that, some all thread and some Unistrut can be made to work. CZ
            • xssiveone
              • 766
              Gawd Brian,
              Fred, you are correct... a lot of work, but it did work. I didn't think we could "see" enough of the race to get a chisel on it. Will have to keep this in mind if I ever have to do this again.. sounds easier then the Dremel wheel.
              Brian
                Hi Brian,
                Don't force it.... use a BIGGER Hammer
                Good to see you are working on an XS11
                  +1. What he said.
                    I broke a few chisels doing it freds/phils way...
                    Cut it off, way easier.
                    • petejw
                      • 2269
                      • sydney australia
                      jat, if u do go the way of using a chisel and hammer
                      throw a rag over the bearing, ive seen bearings shatter
                      and its usually not a pretty site.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      1981 xs1100 RH (aus) (5N5)
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • brcree
                        • Mar 2010
                        • 388
                        • S.C.
                        bearings
                        Whooooweeeeee!!!!!! Got it! You guys are great! I managed to get both races out of the old frame. Put them in the other frame....all bearings look good as do the races!!!!! Saved 45 bucks on new bearings as-well!
                        At this time:
                        1985 Goldwing Innr.
                        2007 vtx 1300
                        81 sx 1100 s h
                        81 sx 400 special
                          I thought we were talking about getting it off the lower triple tree. Boy I am confused...
                          • brcree
                            • Mar 2010
                            • 388
                            • S.C.
                            bearings....
                            I was trying to get the bottom bearing off. After looking at it and seeing it was ok....why go through the trouble? I didn't think I could get the old races out of the other frame but did. Good thread...got me to thinking.
                            At this time:
                            1985 Goldwing Innr.
                            2007 vtx 1300
                            81 sx 1100 s h
                            81 sx 400 special
