oil change
  • happyjj
    • Apr 2004
    • 56
    • Kansas City MO
    oil change
    I trying to change the oil but it won't come out. I warmed up the engine 2 times all that come out is what is in the filter. HELP
  • happyjj
    • Apr 2004
    • 56
    • Kansas City MO
    I ment to put I'm trying to change the oil, Not I trying to change the oil.
    • John
      • 5117
      Which drain plug are you removing?The one that is behind and to the left of the oil filter?
      • iamphotog
        • Mar 2005
        • 19
        • Lufkin, Texas
        there is a drain plug in the oil pan just behind the filter housing. It is facing the filter. I think it requires a 19mm wrench. Also make sure you are on a level surface and you have the bike on the center stand.
        Scott
        1980 SG
        • happyjj
          • Apr 2004
          • 56
          • Kansas City MO
          Thanks guys I forgot about the drain plug. All I did was take off the filter. I'm 52 and loseing it. Maybe I should go back to drinking.
          • randy
            • Dec 2003
            • 4521
            Let the oil cool first before you drink it.
            • happyjj
              • Apr 2004
              • 56
              • Kansas City MO
              I will let it cool first before drinking. It was a 19mm. Now I think I will go out for a cruise. Its about 70 here today in Kansas City,MO
              • John
                • 5117
                What's wrong with a 'hot toddy'? To early in the day? It must be 5:00 somewhere!
                • happyjj
                  • Apr 2004
                  • 56
                  • Kansas City MO
                  got to be
