I have what I think is a stuck float on my 78E. When i start the bike or turn the petcocks to prime I get gas comming from the carb inlets and running into the airbox. The bike will start up and run but dumps a lot of gas into the airbox. The gas appears to be runnimg out of the number 3 carb. The carbs were rebuilt last summer after the PO let the bike sit for five years. I relined the tank but I am not real happy with the way it came out so I plan to do it again. I have not added inline filters, but plan to. I need any help any one can give me. As an FYI before this problem cropped up the old girl ran fine, and returned around 40 MPG.
I have used seafoam in the tank and directly into the fuel line for that side. I've pulled the drain plug of number 3 and number 4 so it would run freely thru the carbs. I've also gently tapped on the carb and ran air thru the line. This is about as far as i feel comfortable doing. Thanks for any help.
