Brakes Howl - HELP!
    That's what they are supposed to look like! Put a little gob of disk brake lubricant (silicone grease) between the shim and the back of the pad or you might just trade your brake howl for brake rattle.
    • randy
      • Dec 2003
      • 4521
      I cut them out from aluminum flashing material that I had lying around. They don't rattle, but if they do i'll grease 'em.
      Thanks again.
      • randy
        • Dec 2003
        • 4521
        I'm still curious as to why the shims disappeared from the '79 fiche??
        • Snow
          • Oct 2002
          • 1041
          • Tallahassee, FL
          Not to revive a dead thread, but I came across this trying to solve my howling front brake problems...*very* embarrassing on campus as I make everyone think the bus is coming
          So, I bought a bottle of brake lube (synthetic, in the permatex/loctite isle - large bottle about $7, two small packets were $3.50! ).
          Began work on rear, was happy to find a brake shim there (no rear noise of course). Then drew a template and cut two new shims for the front - one right and one left out of 1 pop can (Diet Rite Tangerine to be specific).
          I then lubed up the back of the pads, the shims (after installing pads and shim), caliper bolt spacer (in caliper, has boots - had to really pressure them to get them moving. Lubed solved that), and caliper bolt spacer bolt. For some un-resize photos of the original shim (and soon to be template):
          Again, this is the shim from the RIGHT side - left is opposite facing. Another note, yes that's my '89 Mustang GT in the background - brought back from the dead If you wanna see what she looked like the day I bought her, go here:
          • 79XS11F
            • 3563
            • Ottawa, Ont. Canada
            So did the front brake squeal get cured?? I put new pucks all round this year and the brakes were fine. They just started to squeal last week end and the only way to get rid of it is to apply the brakes hard. I do not remember my original 1978 XS11 ever having squealing brakes and for what it's worth that bike like this one (79) also did not have the shims your talking about.
            Rob
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
            • Snow
              • Oct 2002
              • 1041
              • Tallahassee, FL
              This was on my '78 - there was absolutely not even a squeak after working on them this time during my 20 mile test ride Too bad it's pouring today and I had to drive the cage...just wish I would've thought to use my waterproof backpack though.
              The pads I got were EBC and not chamfered.
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                good ol' coca cola
                I second the aluminum can shim... done it to a few calipers, the aluminum is a better heat sink too....
                MDRNF
                79F.....Not Stock
                • 79XS11F
                  • 3563
                  If someone has one of these shims perhaps they could post a traced template.
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
                  • Snow
                    • Oct 2002
                    • 1041
                    • Tallahassee, FL
                    Forgive my lack of tracing/transcribing/measuring skills. Here's the large version:
                    • 79XS11F
                      • 3563
                      Thanks Snow ... So what holds them in place? Are they bonded to the back of the pucks?
                      Rob
                      1978 XS500E
                      1981 Suzuki GS1100
                      • Snow
                        • Oct 2002
                        • 1041
                        • Tallahassee, FL
                        There are three tabs, two at the top and one at the bottom - they are easier to see in some of the photos. I also applied brake grease on both sides of the shim as the thinner soda can aluminum didn't want to stay put on the calipers while installing.
                        Here's a clearer photo showing the tabs:
                        • olebiker
                          • Aug 2007
                          • 692
                          • Kingston ON
                          Ok so is this why I get a squeal from the left cal. only as it is the only one that my front hand lever operates. Are the xs brakes set up the same as my 82xj ?
                          http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
                          • malber
                            • Sep 2006
                            • 568
                            • Belmont, NH
                            The XJ came with linked brakes. The XS did not.
                            1981 XS1100SH
                            • 79XS11F
                              • 3563
                              Perfect .. thanks again for the pics Snow
                              Rob
                              1978 XS500E
                              1981 Suzuki GS1100
                              • olebiker
                                • Aug 2007
                                • 692
                                • Kingston ON
                                Thanks!
