Electrical grease
  • motorandy
    • Aug 2002
    • 8
    • Phoenix, AZ
    Electrical grease
    Hello Gang,
    It's my turn to clean all my electrical connections. I know to take one apart, clean it and put it back together. *grin* But, I had read somewhere about an electrical grease that prevents corrosion and conducts electricity. It's not the dielectric stuff. I know that doesn't conduct. I'm looking to do this job just once and it seems like the conducting grease along with a good cleaning should do the job. Questions are:
    1) Can I buy this grease online and where?
    2) Does anyone make a small round wire brush to fit inside the female bullet connectors to clean them out?
    As always, I appreciate everyone's input here. It's a great forum!
    Randy
    79F
    Phoenix, AZ
  • randy
    • Dec 2003
    • 4521
    Randy
    I've got the conductive grease. It's copper powder suspended in a dielectric grease.
    $2.50 a tube
    Randy
    • motorandy
      • Aug 2002
      • 8
      • Phoenix, AZ
      Randy,
      How do I buy a tube from you? And, how do YOU clean the inside of the connectors?
      Thanks,
      Randy
      email address:
      motorandy@yahoo.com
      • randy
        • Dec 2003
        • 4521
        I just PM-ed you with the details.
        I clean the inside of the teeny weeny connectors with a few bristles of a wire brush and a bit of the old in-out, in-out. Or, you can roll up a piece of sandpaper and ream 'em out. If you use a wire brush, be sure to disconnect the battery. Some of the connectors near the rectifier and fuse box are live all the time. Don't ask how I know.
        It's painstaking but effective. I also understand that you can use a vinegar solution on brass and it works well, but most of our connectors are tinned, so abrasive cleaning does a good job.
        As a last resort, you can replace a connector that's gone. There are posts here about sources, or try here:
        Look under Electrical / Connectors and Terminals
        Cycle Recycle
        • xssiveone
          • 766
          • Windsor,Ontario,Canada
          I found some small round brushes that were used for cleaning the small parts of a paint spray gun that work pretty good.
          Brian
          remembering the same thing!
          • randy
            • Dec 2003
            • 4521
            And, motorandy had a good idea. He's going to look for small bore gun cleaning brushes. Do they make them for BB or pellet guns? That size would be about right. Anyone know?
            • don07tncav
              • Oct 2004
              • 358
              • West Tennessee
              Don't know about no -a-days but a few years ago Wal-Mart had the bore brushes that fit BB guns.
              Don
              99 Valkyrie Interstate named Drakker
              81 XS1100 H Peppylebleu sold and gone to a good home
              81 XS1100 Midnight Special Peppyledeux sold and gone to another great home
              • motorandy
                • Aug 2002
                • 8
                • Phoenix, AZ
                Follow up information
                Well gang...
                I've completed the task. And, EVERYTHING works great now! My tach was working intermittently, sometimes the headlight wouldn't come on and the turn signals were erratic. Well, all the gremlins are gone. All the lights are bright and I'm a happy camper.
                Things I learned a long the way that may help others:
                1) .17 rifle bore bronze brushes are available at Walmart (~$1.50). These work great to clean out the female bullet connectors. Only buy one, if it gets too smashed down, take a pair of dikes and cut a bit off.
                2) Small #2 china brushes (model car brushes) are great to apply the copper grease. A small amount on the tip of the brush, then insert the brush in the connector and work it around. I even 'painted' the male pins or spades.
                3) The copper grease is GREAT stuff. A small tube is more than enough to do the whole bike. I probably used less than half of the tube.
                4) Neatness counts! You cannot let the copper grease bridge between two contacts. As Randy said, it's VERY conductive.
                5) Patience and allow time. You don't want to hurry though this job and miss a connector.
                It was time well spent. It took a few hours and less than $5 to chase the gremlins away.
                Thanks to everyone's input!
                Regards,
                Randy Sanderson
                • randy
                  • Dec 2003
                  • 4521
                  Randy,
                  Glad it worked out. I've been using this 'secret formula' for years and it works great. Thanks for the tip on the bore brushes. Leaving for walmart now!
                  • Geezer
                    • May 2003
                    • 2985
                    • Willamina, Oregon 97229
                    Originally posted by randy
                    Randy
                    $2.50 a tube
                    Randy
                    That's not a bad price but you don't want electrical conducting grease on connectors. The grease is there to protect the terminals and the strength of the terminals pressing together makes the connection. If you have electrical conducting grease it can short between the terminals of a gang plug…
                    Geezer
                    • randy
                      • Dec 2003
                      • 4521
                      Geezer,
                      That's true, if you're not careful.
                      • Geezer
                        • May 2003
                        • 2985
                        In a pinch you could use anti-seize compound to prevent corrosion on terminals. However it also conducts and could cause shorting.
                        I mention this because everybody should have some anti-seize compound in their toolbox...
                        Geezer
                        • randy
                          • Dec 2003
                          • 4521
                          Yes,
                          OBI-WAN!
                          • Geezer
                            • May 2003
                            • 2985
                            Yes,
                            OBI-WAN!
                            My the Schwartz be with you...
                            Geezer
                            • powerram50
                              • 92
                              • portland,oregon
                              Geezer
                              space balls rules....
                              81 SH for 300 bucks,work in progress.
                              87 dodge d-50,35's,lockers fr&rr,fun.
                              87 dodge d-50,35's,open diffs,wifes.
                              89 dodge spirit,low 17's 1/4mile w/o turbo.
