So I picked up the new xs today and started working on it.
Carbs are all gummed up. Nothing moves. I started to dismantle them. As I attempted to remove one of the pins for the floaters, I broke the metal arm that holds the pin.
Should I continue to clean these or scratch the whole idea and buy a used set? What does a used set cost?
Andrew
Andrew
I was just trying to save you the expense and trouble of tearing them down to the shaft seals. Yeah, the pilot jets can be a real pain. The main jets should be easier since they have a larger open slotted screw head. Some penetrating oil and a little heat like you tried might have gone a ways towards being able to remove the sliders and other stuck parts. You're right, cleaning them right is important, but that was mainly for the pilot passages, and they can usually be penetrated with carb spray and a thin flexible wire. Glad you have the know how and equipment to synchronize them, again was just stating techniques that others have used to save them some trouble. And was just pointing out the availability of very good repair/maintainance info that is in our tech tips....many folks come here and don't bother to peruse them, they just jump in with questions, many of which have been answered in the tech tips, as well as in the forum... searching is another wonderful tool. So.... didn't mean to come across as being "mean", just trying to be informative!
