Front wheel bearings
  • Dark Horse
    • 121
    • Syracuse, Utah
    Greetings XSives!
    I've got a question for the wrench-heads in this forum.
    What's the trick to removing the front wheel bearings so they can be checked and greased?
    My shop manuals aren't much help.
    Are there some special tools I need?
    The manual says, "Move the spacer to access the outer bearing race and tap the bearing out with a drift pin".
    Is this spacer the tube that fits between the left and right bearings? I can't get that to move more than 3/64".
    I'm at a loss here. I'd appreciate any help you can give.
    TIA!
    Bob Udy
    Bob Udy
    The spacer will move, Bob, but it will be tight the first time from years of being pressed from both sides. Slip something substantial (i.e. just about the diameter of the bore) like a cold chisel about 7/8 of the way down the spacer and and give it a good whack sideways on the top end. If the spacer doesn't move over, give it a harder whack. It will move.....
    • Dark Horse
      • 121
      • Syracuse, Utah
      Thanks Ken. I was in hope that you would reply.
      Is there any risk of damage to the bearing when doing this?
      I believe the bearings are in good shape and hope to avoid purchasing new ones.
      When you say, "Slip something substantial (i.e. just about the diameter of the bore) like a cold chisel about 7/8 of the way down the spacer...", do you mean 7/8 of an inch or literally 7/8 down the length of the spacer?
      Thanks for your response.
      Bob Udy
      Bob Udy
        I wouldn't try to take them out unless you plan on replacing them. Once the races are damaged, the bearings will not roll around properly. You can try to use one of those needle greasers that attaches to your grease gun...
        • Dark Horse
          • 121
          • Syracuse, Utah
          I haven't planned on replacing them. They just looked like they needed some more grease. Maybe I'll try your suggestion first and check them again about mid-summer.
          Thanks for your replay, Sid.
          Maybe a poll of the rest of the group to see how many have changed or serviced their bearings is in order. Hmmmm. I'll have to think about that.
          Ride Safe!
          Bob
          Bob Udy
            You want to get the cold chisel or whatever down to just about the far end of the spacer so when you whack it above, it will be pushing sideways against one end of the collar, not just in the middle. Actually, you might even be able to do this with the chisel just down past the top end of the spacer. The gist of it is you will need to generate a healthy sideways force on one end of the spacer to knock it loose. As Skids notes, you might want to have some new bearings on hand in case you screw up the bearings while removing them. Personally, I've never had real good luck in removing bearings without damage.
            • randy
              • Dec 2003
              • 4521
              Bob, you can replace the whole set, with seals for about $20.
              • mason79
                • Mar 2006
                • 1359
                • los angeles, ca
                i'm changing the front wheel bearings today and i am having the same problem, if i get too rough with the spacer tube will i compromise the assembly,
                i just don't wont to take the idiot of the year award from randy,
                i jst need to make it go sideways a little right? seems like it is a bearing itself help!!!
                History
                85 Yamaha FJ 1100
                79 yamaha xs1100f
                03 honda cbr 600 f4
                91 yamaha fzr 600
                84 yamaha fj 1100
                82 yamaha seca 750
                87 yamaha fazer
                86 yamaha maxim x
                82 yamaha vision
                78 yamaha rd 400
                • mason79
                  • Mar 2006
                  • 1359
                  • los angeles, ca
                  okay i got the spacer tube out
                  1) what is it's function?
                  2) there is a flange on one side it bent it a little does it need to be straight?
                  3) which way should it go?
                  thanks
                  History
                  85 Yamaha FJ 1100
                  79 yamaha xs1100f
                  03 honda cbr 600 f4
                  91 yamaha fzr 600
                  84 yamaha fj 1100
                  82 yamaha seca 750
                  87 yamaha fazer
                  86 yamaha maxim x
                  82 yamaha vision
                  78 yamaha rd 400
                  • mason79
                    • Mar 2006
                    • 1359
                    • los angeles, ca
                    okay no problem i looked at the book...
                    History
                    85 Yamaha FJ 1100
                    79 yamaha xs1100f
                    03 honda cbr 600 f4
                    91 yamaha fzr 600
                    84 yamaha fj 1100
                    82 yamaha seca 750
                    87 yamaha fazer
                    86 yamaha maxim x
                    82 yamaha vision
                    78 yamaha rd 400
                    • randy
                      • Dec 2003
                      • 4521
                      Mason,,
                      You need the spacer tube to take the load between the bearings when you torque down the axle nut. The large ring on one end is there to keep the spacer tube from falling away whenever you remove the axle.
                      BTW,
                      Anyone who wants the idiot of the year award is welcome to it....
                      • mason79
                        • Mar 2006
                        • 1359
                        • los angeles, ca
                        Originally posted by randy
                        BTW,
                        Anyone who wants the idiot of the year award is welcome to it.... [/B]
                        i don't think you can just give it away they have to win it right?
                        History
                        85 Yamaha FJ 1100
                        79 yamaha xs1100f
                        03 honda cbr 600 f4
                        91 yamaha fzr 600
                        84 yamaha fj 1100
                        82 yamaha seca 750
                        87 yamaha fazer
                        86 yamaha maxim x
                        82 yamaha vision
                        78 yamaha rd 400
                          Bearing removal
                          Hi Dark Horse,
                          removing those bearings will most likely wreck them. New bearings are easily got and not unreasonably priced. But you can cheat. Like Skids sez, use a hypodermic needle attachment on your grease gun.
                          If your bearings have rubber seals, lift the seal lip with the needle, shove the needle into the race and pump away. If your bearings have metal shields, drill a teensy hole thru and stick the grease needle in there. Carefully check that the seperate outer grease seals are OK too.
                          Fred Hill, S'toon.
