Okay
I have changed the brake fluid, cleaned the lines and have every thing replaced on the front brakes of my 79 xs1100 special. Added brake fluid and pressed the lever. Nothing happened. followed the advice regarding bleeding brakes and still nothing happened. Dead, no pressure build up or anything.
However, up on closer expection I did notice drops of breake fluid coming from the back of the brake lever, where the screw depresses the plunger. I'm thinking this is a leak.
Does this mean I have to replace the master cylider? if so, is it a tough job?
thanks
Teck
thanks
Teck
I think you meant to address Prometheus.
