Hi, all. My '79 Special has been going through rear brake pads faster that I can aquire them.
The rear pads were toasted when I got the bike a year ago. I replaced them, and they lasted about 2500 miles before starting to grind again.
I replaced them again, and they were toasted THE VERY NEXT DAY!!! Simple... rear brake sticking. I disassembled the rear master cylinder, cleaned it and the spooge hole thoroughly, then bled the you-know-what out of it. I ran a whole bottle of brake fluid through to ensure it was clean and flushed.
Less than 500 miles later, I had to replace the pads again, and also the disc. (yesterday). I bought a slotted disc from an '81 Midnight Special.
Would a thinning of the original rear disc (through all of this pad grinding, the rear disc mic'd out at under 4.5) have created enough heat to eat through pads as fast as I am?
What kind of miles are you guys getting from a set of pads?
Am I using too much rear brake?
Are the shop guys selling me inferior pads?
