Head scratcher now. 80g hardbagger w/vetter fairing. New Dunlops Elite II on both ends. New fork oil (15w same as always). Steering head bearings check out good, not loose, not tight. Front fork springs meet specs. Tried different fork air pressure settings and tire pressure settings and rear shock settings. Bike develops a wicked wobble at 95+ and gets worse the faster you go. Fork brace is tight, axle bolts torqued to specs, wheels in perfect alignment. I had this wobble before but figured new tires would make it go away. I also get a slow "weaving" effect on high speed sweepers. I even tried it with the fairing off with no results. What now? New front springs and rear shocks? I used to be able to ride this sucker to speeds that would make me pucker
