will standard carbs fit on a special?
  • madsin
    • Feb 2005
    • 22
    Was thinking about buying a set of carbs,but they are off of a standard model.Is there any difference?
    • 5062
    No difference between models except that the octopus mount. 78 and 79's are the same 80 and 81's are the same. You can swap older and newer carb banks as a set, but you will have to do something with the airbox nipples.
