oil light
  • gaffer77
    • Jul 2004
    • 444
    • gloucestershire england
    oil light
    Hi i got a 79 sf, on reading archives i just want to get some things
    cleared up
    is the oil light connected to warn of rear light faults as well??
    is the oil light for level only and not pressure??
    if so why does it take time to go out on start up if its in the
    base of the engine???
    my bike has new oil and filter did 200 miles fine ,never had a prob
    was freezing cold (for England ) the other day (talking snow)
    did 10 miles light came on ,was on motorway bridge so thought
    sod it if she blows she blows think about consequences if i have
    to and prey to god it would be fine
    i know bad attitude towards bike ,it was sunday i was late for a
    meet ,the bike had given me grief (calipers played me up after a
    puncture) up all night decorating as well keep her happy!!!
    anyway after 10 miles i stopped ,started up, after 10 miles oil light
    came on, another 20 it went out ,and has stayed out since
    just wondered if anyone can clear up the point, is the light
    to measure the level or pressure ,(my level was fine ,so i was
    thinking blocked oilways ,strainer,worn oil pump etc)
    but if its level then that is puzzling unless it really wasnt
    passing back down quick enough ,but thought sensor is sitting in the oil
    so oil shouldnt need to come back down for light to work if its
    already down there ,how much oil goes to the top????
    just a bit puzzled and too many contradictions adding to confusion
    Don't put all yer eggs into one basket ,,,case
  • John
    • 5117
    The oil pressure sender is located just below the carbs. It's the round thing with the wire attached to it. The sender makes a ground for the oil light. It sits in the oil galley that supplies oil to the oil pipe that feeds the cams. There is no level switch i the oil pan. That's on the XJ1100. First, check the obvious, and check to see if the wire is securely attached to the sender. It should have a rubber boot over it. All it senses is oil pressure. The only reason for the light to come on would be a wire shorted to ground, or a sudden loss of oil pressure. You said it ran for a while like that? Did you hear any knocking? If you had oil, then chances are it was a shorted wire, but stranger things have happened. It does not warn of the rear lights being inoperative.
    • gaffer77
      • Jul 2004
      • 444
      i twiddled with that sender when i stopped i presumed it was that
      but when reading xj i presumed they had the same engine???
      i was doing about 50 in top waiting for rattles to come in
      upon which i would have pulled up but nothing!!!
      i did 110 miles that day i forgot my breakdown cover number
      have to put that on my phone doh!!!!! it was a nightmare day
      id had enough of everything so chanced it and it was ok
      just wanted to clear up in my mind before i got into it all
      thanx for help
      • Bubba1954
        • Apr 2004
        • 114
        • Hutchinson, Kansas
        Those oil pressure sending switches are notorious for getting flakey as they get older. When I bought my Eleven from the original owner, he thought that it had low oil pressure because the light would come on at an idle when warmed up good.
        I installed an mechanical oil pressure gauge that uses a small oil line to feed it. Much more reliable then the electronic sending unit.
        I installed a fitting into one of the oil cooler lines to feed the gauge, but I bet one could remove the factory sendinf unit and install a fitting in its place with an oil pressure line to a handlbar mounter gauge if you don't have a fairing.
        See the links below:
        http://www.fototime.com/C6629D885A8D440/standard.jpg
        http://www.fototime.com/69496DE314A4664/standard.jpg
        Bubba
        Bubba1954
        (aka) Shannon Koehn
        Hutchinson, KS
        http://www.fototime.com/inv/0EE87CEC5C8C774
        • gaffer77
          • Jul 2004
          • 444
          thanx Bubba that looks snazzy as well i prefer a guage
          have to think on that one,thanx for reply
          • MAXIMAN
            • Jan 2005
            • 1817
            • As far from the government as humanly possible.
            When the weather gets cold this is typical behavior for my 1100. Especially when I still have summer oil in it (20-50 or 10-40).
            However when I change to cold weather oil (5W-30) I never see the oil light.
            • gaffer77
              • Jul 2004
              • 444
              could be that with mine am using car oil weather never been that cold with this bike before ,thanx i will check it out you guys are great and very helpfull for these stupid questions you get
              but i needed help so had to ask sorry!!!!
                • 7693
                gaffer77;
                The only stupid question is the one you don't ask. Nobody can know everything, and this forum is a great resource for all of us!!
                Ray
                • Dennyz
                  • 1151
                  • Olympia, Washington
                  The oil light also can indicate a burned out filament in the tail light on a Special.
                  DZ
                  Vyger, 'F'
                  "The Special", 'SF'
                  '08 FJR1300
                  • gaffer77
                    • Jul 2004
                    • 444
                    hi i thort i read it somewhere some say it is a rear light warning as well others say no , i will dig all my books out ,just buried at the mo!!!
                    • Do Lee
                      • Feb 2003
                      • 255
                      • Victoria, Texas
                      Yes on the Specials the oil light does double duty by also indicating if any part of the braking system or running light has problems. This includes rear brake/tail light fillement, front and rear brake switches. On my 79 Special I would be riding and the oil light would flash on forr a few seconds and then back off or would stay on for a few minutes and then go back off. Found out that my front brake switch was going bad. After replacing the switch I will see a flash every now and again this is also caused from the new switch. I don't pay that much attention to the light anymore.
                      Do'Lee
                      XS1100SF "Green Hornet"
                      (1) XS1100LG "Midnight Dream" Restoration has begun.
                      (2) XS1100LG "Midnight Madness" Waiting to be next
                      (5) multi partsters for bobber "Ruby Red II" On the list.
                      SR500H "Silver Streak"
                      • John
                        • 5117
                        Wow ...I am still learning new things every day. I didn't know that about the oil pressure light. That's good to know.
