This may be something for the Tech Tips
My XJ had about 25k and as far as I know never a valve adjustment. Had quite some vibration at 5k on up. Did some asking and got several ideas. Somewhere along the way I lost a rear support bolt from the muffler, one with the rubber gromet. Well that caused the muffler to crack. Got that repaired then after another nice two up trip I notice the other side cracked, as well as two cracks at the muffler joint, and it's ben welded once before by po. The local shop put me intouch with a restorer. He suggested timing chain and valve adjustment. I have done the chain adjustment by the book several times, even tried with the engine hot, but never felt or heard the spring move. So into the shop and have the valves adjusted. Now, for the tip, Mouse the mechanic says he adjusted the cam tension when he finished the valve adjustment and heard the spring jump. I told him I did that several times and never heard it.Oh! he says I don't do it that way. He runs the rpm up to smooth no clunking and makes the adjustment with engine running , I suppose that takes care of any slack hanging at the bottom. Now with the valves adjusted and tension set, runs really smooth, even sounds different.
Here's the difference. I once let the wife try her hand in the rider seat and I took the back. At that 5k figure felt like my feet were about an inch above the pegs, but now there's barely a hum.
So now with the vibration fixed I have new exhaust system on order to replace the pached originals on the bike now.
Guy
Guy
