Lost key--- Replace or Customize?
  • Springer
    • Aug 2003
    • 76
    • Richmond, Virginia
    Okay fellow XSives,
    Your challenge should you choose to except it is. How do I get around the ignition key being lost. What wires to I need to wire to a switch toggle or whatever to make it work. Also how do I get the gas cap off without the key. This is why I dont take the keys out of the bike I lose them. Crap...
    I am in need of some XSiveness for this weekend.
    Thanks
    John
    Madness comes from within.
    78 XS 1100 E (at Birth) "Madness"
    79 XS1100 parts bike "hunk of junk"
    83 Sportster "Lunacy"
    72 Shovel "Dark Shovel"
    Hey there Springer,
    The gas cap is easy, there's a little spring loaded lip on the front/forward end of the cap, you just need an angled slightly pointed piece of metal to pry under the cap edge, and pull away from the center of the cap "while" pushing down a little on the cap to release the catch, and then the cap can be opened! I thought there was a number etched into the lock mechanism on the cap, or even the ignition switch, that you can jot down and take to your local Yamaha shop and they can cut you a new key!?
    As for the ignition, just short the RED wire to the YELLOW wire, and you should be good. The Blue wire is only for setting the Parking lights in Park Mode.
    While you have the Ignition switch out, you can take it to a Locksmith and they can make a key as well, so depends on which way you want to go at it!?
    Good luck and have an Excessively good time!
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      What # is on the ign. and or fuel cap? Someone may have a match and can cut/send you a key.
      On the triples list someone setup a database with owners/key numbers so we help each other out. He keeps this list private, not open to the public. He's lets the person with a key know someone needs a copy and passes contact info on. This person also won 600 XS keys on Ebay so alot of the time he has it himself.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • UncleSpot
        • Jun 2004
        • 383
        • Home: Stockton, California Shop: Lodi, California
        triples list??
        Hey Pat,
        *where* does one find the triples list? I've looked all over the XS11 board; 'thought it would be in either it's own subdir. or under Links... also did a Google, Webcrawler, and Lycos search.
        ...'couldn't find a single mention.
        __________________
        Ron Veil
        <Ron_Veil@yahoo.com>
        1980 XS1100SG
        • Pat Kelly
          • 3046
          • Golden Valley, AZ
          look in Yahoo Groups and search XS750 (also XS1100 for the 'other 1100 group).
          Also check (I think) www.ytriples.com
          Pat Kelly
          • Dennyz
            • 1151
            • Olympia, Washington
            Take the number to the Yammy dealer and they will order you a key. I have done it several times.
            DZ
            Vyger, 'F'
            "The Special", 'SF'
            '08 FJR1300
            • Do Lee
              • Feb 2003
              • 255
              • Victoria, Texas
              You can also call your local locksmith and ask them if they have key blanks and the key codes for your model. If they do than they can cut you a new key. The Yamaha shop I worked at also had a locksmith shop and he had all the motorcycle code books and key blanks. Yamaha, honda, kaw's etc... the numbers on the ignition switch, gas cap and helmet lock are the codes needed for the new key.
              Do'Lee
              Do'Lee
              XS1100SF "Green Hornet"
              (1) XS1100LG "Midnight Dream" Restoration has begun.
              (2) XS1100LG "Midnight Madness" Waiting to be next
              (5) multi partsters for bobber "Ruby Red II" On the list.
              SR500H "Silver Streak"
              • Springer
                • Aug 2003
                • 76
                Many Thanks
                You guys rock.
                Thanks A ton. I will take the number to the locksmith for starters. as for tommorow I may just short it.
                Thanks again....
                CHEER!!!!!!
                • xssiveone
                  • 766
                  • Windsor,Ontario,Canada
                  Take the ignition with you. Any competent locksmith can make a key from it, and the number pn it might not mean anything to anyone outside of the Yamaha dealer.
                  Brian
                  remembering the same thing!
                  • Czekus21
                    • 1069
                    • Keosauqua (Southeast) Iowa
                    I agree with just taking the switch or helmet lock to a competent lock smith and have them cut you a new key.
                    S.R.Czekus
                    1-big XS patch
                    1-small XS/XJ patch
                    1-XS/XJ owners pin.
                    Just do it !!!!!
                    • railroad
                      • Aug 2004
                      • 28
                      • San Diego,CA
                      Samething happened to me take the ignition switch out and take it to a lock smith there is a number on it that he can use to make a new key, about $15
                      SETH MILLER
