Octupus question
  • dabien310
    • 34
    • Queens, NY
    Octupus question
    Ok... I've read everything I possibly could on this and this is what I have gathered.
    1.)Everything in the diagram I have done... hooked up the tubes from the octi to the petcocks and the vacum to the intake manifold nipple.
    2.) The gas lines from the octi are they supposed to have a T at the end of them to place between the carbs1&2 and 3&4? Mine end as a single tube outlet. And I assume these go in the lower slots right?
    3.) The upper holes (where the T's fit to the carbs) are they just atmospheric vent lines? They just get shoved somwhere to get them out of the way right?
    The only question that i need clarification on is How to connect the gas lines from the Octopus to the carbs.
    Thanks for the input.
    Jon
  • Bob Falter
    • 321
    • Ely, Iowa
    2) Yes.
    3) I'm not home so I can't go look for sure but if you are talking about some hoses that are bigger than the gas line hoses, I believe they are carb vents and they go to fittings on the air cleaner box.
    #1 ’79 XS11 Special
    #2 ’79 XS11 Special
    '97 V-Max
    '01 Dyna T-Sport
