Bigger Carburetors
All FJ carburetors were not the same and even though the throttle plates all measure 36mm,there was one flavor for the 84,one for the 85 and one for the later models and the later ones are still available from Yamaha. How much air does a 34 mm CV Mikuni flow and how much air will an 1100 cc 4 cycle engine pump at 80% VE & 100% VE @ 9000 rpm? A stock 80-83 XS-XJ Yamaha's cams only have 235 degrees of duration and subsequently the motor does not require the airflow of a 36mm carburetor.Remember the Suzuki Madura,don't see many of them around do you.
Originally posted by strom
AFAIK the japanese stuff mostly used either keihin or mikuni carbs. Neither of these companies can afford to make "cheap" carbs.
Next, try finding a nice suzuki katana 1100 in a pristine working condition. OK, any suzuki inline-4 up to 1990. I know of only one GSX 750, and even that one has a half of kawasaki parts installed.
Try the same with any yamaha.
And while you're at it.... polish the insides of your steel carb, adapter pipes. And for goodnessake put some K&Ns on.
LP
LP
