The horn, she no worky......
  • XSiveForce
    • Aug 2004
    • 7
    • Bklyn NY, Lake Ariel. PA
    Gents,
    I replaced the original horns with the ones that come in the Vetter Fairing. When I sit at idle, they no worky. But, of course, as I ride, they sound just fine. And...yes its a BRAND NEW, fully charged battery. All the connections are clean and neat. Any suggestions?
    Bobby
    So what my bike is purple...your point is? At least I can listen to the radio, and hear it too, while I ride...whats your excuse?????
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    I'm not a fairing guy, but I'll take a stab. I'm guessing that the fairing is new to the bike, and there were no horn related or otherwise electrical probs prior. Weak charging system, regulator/recifier going out, or just too much extra draw on the system with the radio, extra lights, etc. Not enough juice flowing at idle, but kick up the RPMs a little and the system puts out more. I'm sure the fairing guys can correct me if I'm wrong and supply some experience based knowledge.
    • randy
      • Dec 2003
      • 4521
      Bobby,
      Horns draw a lot of current. More than most lights. Try running a seperate lead for the horn, bypassing the fairing's multi-pin connector.
      HTH
      Randy
      • Pat Kelly
        • 3046
        • Golden Valley, AZ
        From day one my horn hasn't worked. Every 6 months or so it will give a feeble ½beep then nothing. Not really an issue for me.
        Pat Kelly
        <p-lkelly@sbcglobal.net>
        1978 XS1100E (The Force)
        1980 XS1100LG (The Dark Side)
        1999 Suburban (The Ship)
        1994 Dodge Spirit (Son #1)
        1968 F100 (Valentine)
          I and many others here have installed car horns on our bikes. It's easy to do and the only thing extra to install is a horn relay. The job should only take about an horn, including the time it takes to remove and reinstall the tank. If you're interested, I'll describe the install to you. I believe there are detailed instructions on this site. Just look around in the tech tips, or mods sections.
            Pat, "hand signals" in lieu of the horn *might* be mistaken for road rage! :-)
            • rover
              • Jan 2004
              • 765
              • central WI (715)
              The stock horns have an adjuster, a funny looking screw near the side of the horn with a lock nut on it. Other horns should be run through a relay with 10 or 12 guage wiring
              79 F (Blueballs)
              79 SF (Redbutt)
              81 LH (organ donor)
              76 CB 750 (gone to MC heaven)
              rover has spoken
                Hey there XsiveForce,
                As per already suggested, run a separate tap from the fuse block as the main power for the horns, the power side of the relay! And then ground the horn to the frame. You can use the positive horn wire for the positive switch side of the relay, and the ground side of the switch connects to the wire that goes to the horn switch on the handlebar. The regular horn circuit runs power thru the horn, and then grounds at the switch, but it's not a very large power line, and the ground at the switch may also not provide a good contact for good flow of the power needed to make a horn really blast! HTH.
